I posted earlier on removing the windscreen washer bottle and ended up removing the bumper to get to it.
With the bumper off, I can see that the inner wheel arch on the right hand side is cracked and could do with being replaced. It looks like I can pick one of these up for not very much money at all, so I may as well fix this while the bumper is off.
Does anything other than the wheel need to be removed to replace the inner wheel arch? Can anyone who has done this give me some advice please?
Secondly, some of the little Torx screws that hold the bumper to the inner wing arch were missing - does anybody know the correct part number or dimensions for these? They are a T25 head, but I don't know anything else about the thread type....
2005 Polo inner wheel arch? (and screws?)
adentonmiller
- Drives: 2005 MK4
adentonmiller
- Drives: 2005 MK4
Re: 2005 Polo inner wheel arch? (and screws?)
So, the inner wheel arch panel is now out. Pretty easy. New one ordered.
And I think I found the correct panel screws on eBay for cheap! Torx self tapping panel screws, 15mm diameter head, 16mm shaft, 4.8mm diameter.
All is good!
All is good!
These screws are screwed into plastic retainers which snap into the car's metalwork, you might find that some of these plastic retainers are split, VAGBOLTS seems to be one of the online suppliers of these sorts of screws, I have just bought 10 of the slightly larger size which newer cars seem to use there and other places.
I'll try to find the p/n of the retainers and post them here for you.
Retainers/expanding nuts N908 338 01 which get used with screws N907 750 01 and some other numbers.
adentonmiller
- Drives: 2005 MK4
Excellent - thanks for that! I have ordered some from eBay to be on the safe side.
The screws I ordered already come with the metal speed nuts needed for some of the inner wheel arch fixings, but now I can replace the plastic retainers as well while I am in there. I did notice plastic debris on some of the screws earlier, so I am certain that it was from those.
As my old man used to say - "If a job's worth doing, it's worth doing well."
littlepolo
It's easy to see the fluid level in the power steering reservoir while you have the bumper off too.
adentonmiller
- Drives: 2005 MK4
Good point! The steering was working fine, but I just went and had a look and the level is indeed just below the min mark.littlepolo wrote: Tue Apr 30, 2019 8:48 am It's easy to see the fluid level in the power steering reservoir while you have the bumper off too.
Power steering fluid added to list of things to buy!
Thanks for the heads up!
Just to be safe make sure that you buy the correct spec of power steering fluid, it should be green and to whatever spec is needed for VW Group cars and maybe even written on the reservoir tank cap.
My experience of these plastic clips breaking/hardening comes from working on a 2000 VW Passat 4Motion when it was maybe 8 years old, back then the material was wrong and so was bio degrading which was made worse by the fact that the exposed inner section of the threads of these screws can corrode and so grow - and dragging them out through these retainers is not good for them, so they can split. I think that Polo's retainers will be better material and the replacements certainly will be.
Edit:- your plan should be to buy as small a container of steering fluid as possible and that system will need very very little to bring it back up to the HOT MAX, the lower marker, I think, was for COLD MAX and not MIN. If it touches or wets the button on the base of the cap then in my world that is good!
adentonmiller
- Drives: 2005 MK4
RUM4MO wrote: Tue Apr 30, 2019 10:02 am Just to be safe make sure that you buy the correct spec of power steering fluid, it should be green and to whatever spec is needed for VW Group cars and maybe even written on the reservoir tank cap.
