Hi there,
I have one 9n from 2003, I have some issues with egr valve. I change it with new one(egr), and I have the same problems. What exactly do?
Start the engine, everything is OK, if I push the acceleration till 3.500-4.000 rpm is opening on board check engine, epc and abs lights. If I am moving with the car and I accelerate for a few km. continuu till 2.500-3000 rpm the car start to shake (this is because is automatic and I think there is a probleme with changing speeds ore something).
Can someone to help. Thank you!
Sorry for my eng.
Egr valve
littlepolo
Re: Egr valve
Assuming you read an error code that specifically indicated an EGR problem?
You need VAG software tools to reset the EGR after replacement.
