Guy I’m looking to find anyone that can help who has Blind Spot Detection on there polo.
I’m currently getting the parts together to do this but I really could do with the Coding for this so if any has VCDS that can give me Scan info that would be awesome.
Scott
Blind Spot Detection Help
- Drives: 2018 Polo GTI +
Re: Blind Spot Detection Help
You could always go down the kufatec route..Scotty_boy vw wrote: ↑Fri May 10, 2019 6:41 pm Guy I’m looking to find anyone that can help who has Blind Spot Detection on there polo.
Scott
https://www.kufatec.com/en/volkswagen/v ... -aw1-42675
I have the parts and looms and Kufatec have said that they don’t do this for RHD vehicles.
It’s the coding help that I need from someone...if I could get a scan and channel maps of some modules that would help massively.
Scott
Scott
Ahhhh, OK, I do have blind spot monitoring on my car but unfortunately I have an older VCDS Hex Can which doesn’t work properly on the latest vehicles.Scotty_boy vw wrote: ↑Sat May 11, 2019 7:55 am I have the parts and looms and Kufatec have said that they don’t do this for RHD vehicles.
Scott
- Drives: 2019 Polo GTi+ in Reef blue
My GTi+, which is currently on a ship somewhere off the west coast of Africa, has it installed (was pre-ordered car, I wouldn't have spec'd it myself). If you have no luck before I get mine I could look for you if it is possible to do with OBDEleven?
What extra hardware is required for it, does it get extra sensors in the rear bumper etc?
Guys a question about how the blind spot works.
1-Do the indicator squares light up when the system starts and when the system warns you. (Not when indicating)
2-Also is there a warning in the cluster when the system alerts you
Scott
Scott
- OomStu_ZA
- Drives: 2019 VW Polo GTi
1-Do the indicator squares light up when the system starts and when the system warns you. (Not when indicating)Scotty_boy vw wrote: ↑Sat Jun 01, 2019 7:21 pm Guys a question about how the blind spot works.
Scott
1 - Yes, they light up briefly when starting the car (not start/stop) and Yes, they light up solid if another vehicle is in the blind spot. They also FLASH if you're indicating and the lane is blocked by a vehicle in the blind spot.
2 - No that I have seen
