Hi all,
Apologies if this information is somewhere obvious, but I've had a look through the fuse diagram and can't find anything.
I've been trying to fix the Mrs Polo as both tail lights are out. All other lights are working as far as I can tell. I changed both the bulbs and when this didn't fix the issue I realised that a more obvious answer would be the fuse had blown. However, for the life of me I cannot figure out which fuse is for the tail light. Does anyone know? I heard a nasty rumour that there isn't actually a fuse for the tail lights at all. Is this true?
Tail Light Fuse
stefan9107
- Drives: 2012 VOLKSWAGEN POLO MATCH 1198cc
Re: Tail Light Fuse
It is true.
But there is a fuse for feeding various lights that are controlled by the BCM.
Check fuse 21, usually red 10A.
(30G, 58L, 58R are the signals fed by this fuse through the BCM)
Good luck!
Good luck!
