Another Wiper Problem
Bloke
Drives: 2007 1.4 tdi
Post by Bloke »
Hi, the front wipers have stopped working so I've ran an autoscan on VCDS but it shows some other problems but nothing to do with wipers. Any help?
VCDS Windows Based VAG/VAS Emulator Running on Windows 10 x86 VCDS Version: Release 18.9.0 Data version: 20180927 DS296.0 www.Ross-Tech.com
Dealer/Shop Name: Workshop Code: 000 00000 000000
Self-Diagnosis Log Thursday,25,July,2019,17:13:33:00007
VIN: WVWZZZ9NZ7Y204190 License Plate: SD07FPX Mileage: 170900km-106192mi Repair Order:
Chassis Type: 9N (9N - VW Polo (2002 > 2010)) Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ7Y204190 Mileage: 170900km-106192miles ------------------------------------------------------------------------------Address 01: Engine Labels: Redir Fail! Part No: 045 906 019 BP Component: 1,4l R3 EDC 0000SG 8395 Coding: 00002 Shop #: WSC 00788 VCID: 64C71A91F45BB86A51-4B18 WVWZZZ9NZ7Y204190 VWZ7Z0G5278061
3 Faults Found: 18043 - Powertrain Data Bus P1635 - 35-10 - Missing Message from A/C Controller - Intermittent 18045 - Powertrain Data Bus P1637 - 35-10 - Missing Message from Electric Load Controller - Intermittent 17911 - Load Signal from Alternator Term. DF P1503 - 35-00 - Implausible Signal Readiness: 0 0 0 0 1
------------------------------------------------------------------------------Address 03: ABS Brakes Labels: 6R0-907-37x-ABS80.clb Part No SW: 6Q0 907 379 AF HW: 6Q0 907 379 AF Component: ABS 8.0 front H05 0002 Revision: 00000000 Serial number: 00000000000000 Coding: 0002136 Shop #: WSC 00788 785 00200 VCID: 010933055B090D42DA-515A
1 Fault Found: 18265 - Load Signal P1857 - 000 - Error Message from ECU - Intermittent
VCDS Self-Diagnosis Log Thursday,25,July,2019,17:13:33:00007 Page 2
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl Part No: 6Q0 820 045 Component: Klimaanlage X0840 VCID: 6ADB74A9167FEE1A6B-515A
3 Faults Found: 01596 - Motor for Outside/Recirculated Air Flap (V154) 30-00 - Open or Short to Plus 00819 - High Pressure Sensor (G65) 07-00 - Signal too Low 01299 - Diagnostic Interface for Data Bus (J533) 49-10 - No Communications - Intermittent
------------------------------------------------------------------------------Address 09: Cent. Elect. Labels:. 6Qx-937-049-C.lbl Part No: 6Q1 937 049 F Component: 0009 BN-SG. 2S36 Coding: 09358 Shop #: WSC 00788 VCID: 3E7388F93A77B2BAE7-515A
------------------------------------------------------------------------------Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl Part No: 1C0 909 605 K Component: 18 AIRBAG VW51 0P 0010 Coding: 12600 Shop #: WSC 00788 VCID: 2C57B2B1DC0B302A59-513C
------------------------------------------------------------------------------Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl Part No: 6Q0 920 903 R Component: KOMBIINSTRUMENT VDO V06 Coding: 01432 Shop #: WSC 00000 VCID: 408FF6014083C44A95-515A
1 Fault Found: 00457 - Control Module for Network (J519) 49-10 - No Communications - Intermittent
VCDS Self-Diagnosis Log Thursday,25,July,2019,17:13:33:00007 Page 3
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl Part No: 6N0 909 901 Component: 01K1 GATEWAY CAN 2S36 Coding: 00014 Shop #: WSC 00788 VCID: 70EF66C130A314CA25-513C
------------------------------------------------------------------------------Address 25: Immobilizer Labels: 5J0-920-xxx-25.clb Part No: 6Q0 920 903 R Component: IMMOBILIZER VDO V06 Coding: 01432 Shop #: WSC 00000 VCID: 408FF6014083C44A95-513C WVWZZZ9NZ7Y204190 VWZ7Z0G5278061
------------------------------------------------------------------------------Address 44: Steering Assist Labels: 6Q0-423-156.clb Part No: 6Q0 423 156 AB Component: LenkhilfeTRW V270 Coding: 10110 Shop #: WSC 00000 VCID: 6FED65BD2D9D0B323C-513C
------------------------------------------------------------------------------Address 46: Central Conv. Labels:. 6Q0-959-433.clb Part No: 6Q0 959 433 H Component: 1N Komfortgerát 0002 Coding: 00019 Shop #: WSC 00788 VCID: 408FF6014083C44A95-4B18
VCDS Self-Diagnosis Log Thursday,25,July,2019,17:13:33:00007 Page 4
Address 56: Radio Labels: 1K0-035-1xx-56.lbl Part No SW: 6Q0 035 152 F HW: 6Q0 035 152 F Component: Radio DE2 0004 Revision: 00005000 Serial number: VWZ4Z4G0190299 Coding: 0020200 Shop #: WSC 00788 785 00200 VCID: 2D51BFB5B71139224E-515A
1 Fault Found: 00457 - Control Module for Network (J519) 004 - No Signal/Communication - Intermittent
End-------------------------(Elapsed Time: 03:14)-------------------------
Re: Another Wiper Problem
Hum, have you ever read threads/postings about the wires being broken or rotted out below the car where the gearbox joins the engine, there are a pair of plugs and sockets each mounted on a steel bracket, one of these plugs and sockets are for alternator load sense and the other plug and socket concerns the AC compressor solenoid control, check fix them then clear the stored faults again. The AC flapmotor failures are typical and you can live with them I'd hope. The AC gas pressure being low will be either a leak from stone damage or just normal gradual loss of R134A across seal material and flexy piping material.
Edit:- by the way, there has been an update for VCDS recently, maybe just last week, so maybe grab it to stay up to date.
Bloke
Post by Bloke »
Cool, thanks for tips. Let's see what I can find.
