TIA
PETE
Written like an expertGroovyCarrot wrote:Advice: don't worry about it, piece of cake
Parts etc: Head gasket, torque wrench, splined sockets (go to an auto accessory shop and tell them what it's for and they'll give you the right sockets). You may want to get a head gasket set, then you can replace the manifold gaskets etc which will probably also be on the way out. Also, a new set of cylinder head bolts is a good idea, or you can just scrub all the rubbish out of the threads of the existing ones.
It's easy to do, just disconnect any cables / tubes connected to the head / distributor / carb / inlet manifold, remove rocker cover, remove head bolts in sequence, lift head etc out of engine bay, remove existing gasket, replace with new gasket, reverse sequence.
While the head's off, you might want to clean the tops of the valves and pistons with oven cleaner, get all the coke off them, and also make sure the surface of the head is absolutely flat. Do make sure you get all the oven cleaner off afterwards though
Damn well should be an expert by now the amount of time I've spent with the thing on a workbenchbstardchild wrote: Written like an expert
water in the oil (evident when the oil filler cap is unscrewed).GroovyCarrot wrote:Oh yeah, if you're doing this because it's using water and overheating, first open the oil filler cap and check for any white residue, and also check for any oil in the coolant water. If you don't see either of them, it's quite likely that there's a water leak from elsewhere. Mind you, it can't hurt to change the gasket just in case, doesn't take long
Exactly what I had. This was my first sign of the gasket blowing, along with a really uneven idle, as it was blowing badly on no.1 cylinder.imense pressure within the water pipes!
They also snap as you do them up if you re-use them and then it's a real pain in the ass as they normally snap on the final tighten up stage....hayesey wrote:you should replace the head bolts. Not because the old ones get dirty but because they stretch when they're tightened back up. Re-using the old ones means they wont lock up as tightly.
Good advicehayesey wrote:Also a very good idea to replace the timing belt & water pump while you're at it. Definately replace the belt if it's done more than 20k since last being replaced.
I'd skim whatever - gives a nice flat surface and gets rid of any water erosion around the water cooling holes so the head gaskets last a bit better. it's only £30 (ish)hayesey wrote:Skimming the head shouldn't be necessary unless the engine has been over heated. But checking its flat with a straight edge wouldn't go a miss.
Correct but although it might be too late - you can warp a head (esp alloy ones) if you don't undo the bolts in the same sequence as they are to be done up - always follow the sequence doing up or undoinghayesey wrote:It's important you progressively undo & tighten the bolts in the correct order to reduce head warping due to stresses of some bolt being tight & other not.
And it needs to be done in one sweep not 4 x 45 deg bits...... A friend is handy here - you start he finisheshayesey wrote:Haynes tells you the orders & importantly the stage of torque to tighten them up to. There are 4 stages, 2 you tighten up to a specified torque using a torque wrench & then 2 stages of 180 degrees. Make sure you've got a big breaker bar and/or scaffolding pole to extend the bar cos those bolts go SERIOUSLY tight.
Well worth doing properly too....hayesey wrote:It's not a hard job though, a bit time consuming but not hard.
