hi everyone,
i want to ask a question about the ECU problems after 7H0937090D upgrading on my Fabia MKII from Chinese Market.
after this upgrading, both vcds and 5054A can not access 01-ECU, both return "no response" when try to access ECU. Does anybody could give some suggestions, if he/she has same or similar situation?
many thanks.
Problems with ECU after BCM upgrading
Re: Problems with ECU after BCM upgrading
Hello
Is address 01 enabled in the gateway installation list?
Have you installed new CAN lines for the Instrument Cluster when you installed that new BCM (Max)?
Please, post a recent full autoscan. Thanks.
hiciclo wrote: Tue Aug 06, 2019 7:49 pm Hello
thanks for your reply.
01-ecu is enabled in the gateway list, and cluster can lines were installed according the diagrams.
i'll post my scan this weekend as i need to find englisht version of vcds.
Thanks.
No problem for me, you can post the autoscan in your language.
edit:
Please, for VCDS, read the part of this post that may interest you. HERE
Maybe you can reach the ECU in this way.
edit:
