Hi, I recently replaced my brake pads with some brembo pads (P85 148), but I don't like the feel of the pedal.
my gti has the 312mm discs (Original pads 8X0698151), i'm having difficulty finding brake pads
https://ecat.ferodoracing.com/car-racin ... ds/FCP1641
http://www.pagidracing.com/en/product-s ... -8001.html
these are the options i found (a bit expencive)
I wanted to try some EBC pads ( redstuff) but I can't find the compatible ones
I would like to hear your opinions, and which ones you are using
thanks in advance for your feadback
Polo 6C GTI brake pads
JaegerStriker
- Drives: 6C GTI
Re: Polo 6C GTI brake pads
ive just replaced mine with the ebc yellowstuff
https://www.carparts4less.co.uk/p/ebc-y ... -93044025Y
and how about the brake pads? good braking? good inicial bite?JaegerStriker wrote: Tue Sep 10, 2019 7:24 pm ive just replaced mine with the ebc yellowstuff
that set have wear indicator?
JaegerStriker
- Drives: 6C GTI
they have the wear indicator but the gti's dont use them so i just cut it off. havent had a chance to fully test them out as im still in the brake in period but they feel great already.amcl wrote: Wed Sep 11, 2019 9:11 pmand how about the brake pads? good braking? good inicial bite?JaegerStriker wrote: Tue Sep 10, 2019 7:24 pm ive just replaced mine with the ebc yellowstuff
- Jay-Jay
- Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
I'm experiencing the same feelings with those Brembo pads on the same brake system.
Now I'm almost at 30% remaining pad's material, so I'm searching online for info about better pads.
Once again, the results of my search bring me to the EBC YellowStuff.
I'm pretty sure I'll go for them!
I find it very strange is that EBC only manufacture these brake pads with the wear warning
- Jay-Jay
Ferodo and Brembo build brake pads with the wear sensor too.
It could be that because EBC are not a very large scale manufacturer, just making all of certain pads with built in wear warning system is cheaper for them than manufacturing 2 different versions, as said already, all you need to do is to cut the cable off if your car does not have that warning system built into it.amcl wrote: Fri Sep 13, 2019 9:56 pm I find it very strange is that EBC only manufacture these brake pads with the wear warning
