Hello everyone just signed up as I need some help with my Polo.
It’s a 2010 Polo 6R 1.2 60
Basically had codes P0341 and P1141 pop up and with some research knew these were common when the chain had stretched. Took it to a garage and had it opened up and the chain was stretched, new chain has gone in and code P1141 has gone however code P0341 still remains, I purchased a camshaft sensor today and put it in however it makes no difference and code P0341 still remains the car was checker over and timing is perfect. Can anyone help with this?
When the cars cold it takes a while to start and without pressing the accelerator a bit will stall however once it’s warmed up a little it’s fine. And starts fine after that.
Thanks.
Code P0341
joe6
Re: Code P0341
If the camshaft sensor is new and the timing is perfect? then suggest a wiring check as the ECM is picking up error voltages from the sensor for the code to persist. Could possibly be the reason for poor cold start.
