No intermittant wipe
Zeno
Drives: 2004 Polo Twist 1.2 12v manual 73k
Post by Zeno »
Decided to remove the wiper motor as it has started making a clicking sound on the up movement, and also to clean out the drain holes.
After stripping the mechanism, greasing, putting it all back together I set about testing the system without the arms for its parking position.
I decided it would be ideal to set intermittent and watch the rotation of the spindles, no intermittent wipe, but ok with normal fast and single sweep.
I decided I must have somehow spiked the electronic delay module as no joy at all with intermittent and resigned myself to a car with no intermittent wipe.
The following day I searched the web for Polo 9n loss of intermittent wipe and found a post explaining that VW design the wipe system to isolate the intermittent wipe when the bonnet is up :o :?.
I can confirm that this post was right. My intermittent wipe does in fact work with the bonnet down and the clicking sound has gone. :roll:
