So I’m looking for help,I have a 2007 9n3 3 dr fitted with remote central locking from factory.
To unlock all doors and tailgate I need to press the remote twice,does anyone know if it’s possible to code the control unit to unlock all doors with a single press??
VCDS or OBDeleven coding steps would be appreciated guys and girls.
Lock and unlock on a single press.
CarbonChaos
Re: Lock and unlock on a single press.
Use VCDS. Go to the comfort system, coding and minus 1 from the coding you have. Pretty simple. Idk about OBDEleven.
Sent from my SM-G935F using Tapatalk
CarbonChaos
Ok, so I have obdeleven pro not vcds and can go to comfort system, coding no problems
The current coding is set 00064 ( remote central locking with front electric windows) which is correct.
Do you mean change this to 00063 ?
CarbonChaos
I have now sorted out the central door locking to how I like it, unlock all doors on a single press of the key fob and lock all doors on a single press also.
The coding you require is,
Comfort system,
Long coding,
Change the 5 digit code from 00064 (on my 3 door with front electric windows)
To now read 00065 ( ie add 1 to the coding)
This works a treat, hope this helps anyone who wants it.
Comfort system,
Long coding,
