help needed airbag light reset or cheap tool
Posted: Mon Nov 25, 2019 11:24 am
Hi, the airbag light just came on all by itself, no reason, no bump or anything !
Its a Polo 6R , 2014 match edition
I tried the manual switch on/ off ignition 3 times thing, but still no go. damn !
Ive got an obdii blutooth & phone app which i use for other car, it doesnt show any fault codes, and there no CEL either.
I bent down, ughh, and wiggled the under seat cables both sides, and switched passenger bag off, but no difference.
Can someone advise the cheapest tool to reset the airbag light, i think i saw one post mentioning U281 or something ?
or
If theres anyone near me, Manchester,with a VCDS or something, that could read off the code for me, / reset the airbag ? i would travel to you.
(I did install a Bury blutooth phone button about 3 months ago working fine, no problems, i used a piggyback fuse on the headlight/no.plate fuse 7, so i checked the fuses in case, but they all look good
many thanks
or
many thanks
