AC doesnt engage when fans on 1
- gaza1994
- Drives: Match 1.4 2012 (6r) (85ps)
hi guys, its been a while! (I've kinda just learned to accept my cars a nugget lol)
New problem that bothers me though!
My AC doesn't engage when the fans are set to '1' but will engage on anything higher!
If i set the fans back to '1' the AC will turn itself off!
The fans blow on all settings
Any ideas as to where i should start to look?
Re: AC doesnt engage when fans on 1
Sorry for asking, but if your fan did not run on speed "1" then maybe the speed controller resistor network is faulty and that would explain this.
Are you 100% sure that the fan is running on speed "1"?
- gaza1994
It definitely feels like there is air coming out when the fans are set to speed 1 (i will triple check tomorrow)RUM4MO wrote: Mon Nov 25, 2019 10:17 pm Sorry for asking, but if your fan did not run on speed "1" then maybe the speed controller resistor network is faulty and that would explain this.
- gaza1994
Hi - checked today, fan doesnt blow on speed 1, but does on all others.RUM4MO wrote: Mon Nov 25, 2019 10:17 pm Sorry for asking, but if your fan did not run on speed "1" then maybe the speed controller resistor network is faulty and that would explain this.
Make sure temp dial is set all the way to min.
I don't think that is relevant in this case, the OP has confirmed that the fan does not run when speed 1 is selected, which I'd guess is a resistor network failure.
- gaza1994
so, this would be the blowy-ma-tron thingie resistor
Part Number(s) 6Q0959263 OR 6Q0959263A
It is 6Q0 959 263A that is currently listed.
- gaza1994
Noticed that there is a few items on ebay that say that their part covers several part numbers
I've been looking at getting this one: https://www.ebay.co.uk/itm/Heater-Blowe ... 1438.l2649
Would that work?
Thanks for your help so far btw
It should work, as the second part number looks to be an updated (for any/many reasons) of the first VW Group part number, how long it will last I don't honestly know as I've never needed to replace one of them ever, never mind with a cheaper pattern part.
One thing, maybe hold onto the one you remove as you know it still woks in all the remaining fan speeds.
- gaza1994
Got the part delivered Saturday and fitted it in about 40 minutesRUM4MO wrote: Wed Nov 27, 2019 2:44 pm It should work, as the second part number looks to be an updated (for any/many reasons) of the first VW Group part number, how long it will last I don't honestly know as I've never needed to replace one of them ever, never mind with a cheaper pattern part.
It works again
thanks for your help!
Excellent!
