ABS Trouble
AlexDuncan
ABS Trouble
Post by AlexDuncan »
So the abs light was on and I fixed the wheel sensor on the front left and the light went off but now a soon as I drive the car the light comes back on and shows fault on both left and right front wheel sensor so just wondering if anyone thinks it’s the abs rings or there is another fault that I can’t clear and it says abs control module defective but the brakes are working fine
Re: ABS Trouble
Don't be mugged into thinking that as the brakes work okay that the ABS faults are not true, if the ABS spots an issue when it runs its self test as soon as you start moving, it will inhibit any ABS intervention, which will leave the brakes working okay but without any help from the ABS.
