Headlight bulb replacement
Falconmick
Drives: 2019 SE
Post by Falconmick »
Guys new to the forum, hope I can add to as well as learning. Recently bought a 68 reg Polo SE and want to improve headlights. I have managed to change high beam but struggling to get to low bulbs. Can anyone point me to any ‘how to’ videos or instructions please? Car has the separate bulbs for low/high. Thanks in advance Mick.
giannis159
Drives: polo aw Rline 1.0 115ps
Re: Headlight bulb replacement
Post by giannis159 »
Hello its very simple you have to take off headlights. It has two h7 lamps for high and low. The headlights its very easy to get them off with two screws. See the manual its easy! I installed in hi and low Philips diamond vision and the have good looking white look.
Falconmick
Drives: 2019 SE
Thanks, there appears to be more than 2 screws to remove, are you able to show a photo please?
When you refer to the manual, do you mean the owners handbook that comes with the car? If so it is not in mine, wonder if different countries have different content?
Instructions for removing the headlamp units from the owner’s manual (in the index it should be under ‘headlights -> removing and installing the headlights’).
‘First read and observe the introductory information and safety warnings⇒Introduction 
The headlight needs to be removed in order to change a bulb.
You will need the screwdriver with the Torx bit from the vehicle tool kit to remove the headlights ⇒ Vehicle toolkit .
Removing the headlight
Switch off the lights and ignition.
Open the bonnet m/k/v155MK⇒ In the engine compartment .
Use the Torx key to remove the screws ⇒ Fig. 161  ①.
Press the bottom of the headlight out of the guides in the direction of the arrow ⇒ Fig. 161 .
Disconnect the connection on the headlight by pressing the connector towards the headlight housing and simultaneously pressing the lug on the connector to disengage. Then remove the connector from the headlight.
Pull the headlight forwards and all the way out of the vehicle ⇒ .
Installing the headlight
Push the headlight into the vehicle until it reaches the upper stop in the middle ⇒ Fig. 161  ②. Make sure that the headlight engages properly into the lower guides ⇒ Fig. 162 ⇒ .
Insert the connector into the connection point on the headlight housing. You should feel it click into place.
Screw the screws ⇒ Fig. 161  ① into the headlight housing.
Push the headlight against the middle upper stop ⇒ Fig. 161  ② and tighten the screws ① with the Torx key.
Close the bonnet and check that the headlight is positioned properly.
Falconmick
Drives: 2019 SE
This is the top of headlight on mine
Sent from my iPhone using Tapatalk Pro
Falconmick
Drives: 2019 SE
Is the metal plate on top of the headlight unit separate and needs to be removed to gain access to headlight securing screws?
Nodster
Drives: Polo GTI
Post by Nodster »
Falconmick wrote: Mon Dec 02, 2019 4:29 pm Is the metal plate on top of the headlight unit separate and needs to be removed to gain access to headlight securing screws?
The black metal plate stays connected to the car. Basically the headlight slots in underneath and there are two torx screws that secure the light to the metal plate, to keep it from falling out. So in that photo, you undo the screw to the top-right (just before the red body work starts) and then you also undo the one just below the washer reservoir cap. And that's it. Then push the headlight forward, it'll pop out of the clips located on the under side, and then it takes a bit of jiggling. And unclip the connector at the rear.
I did mine the other day, and did a bit of cleaning whilst the light units were out. Took like 15 minutes per side to get it out, clean, replace the bulb and refit. :)
PoloBlack
Drives: Polo Beats
Post by PoloBlack »
Nodster wrote: Sun Dec 29, 2019 2:35 pm
Thank you Nodster the bulbs are changed!
