Tyre pressures
Slider09
- Drives: 2015 Polo 1.2 SE
Tyre pressures
1.2 TSI owners - What’s the recommended tyre pressures for the standard 185/60/15 tyres please?
The tyre pressure plate on our car says 38psi, but I don’t think this is correct.
- Black6c
- Drives: 6c 1.2 (110) TSI DSG
Re: Tyre pressures
I put 39 psi front and 36 rear. Even when I had 185/60 R15 and even now with 215/45 R16.Slider09 wrote:1.2 TSI owners - What’s the recommended tyre pressures for the standard 185/60/15 tyres please?
Falconmick
- Drives: 2019 SE
Re: Tyre pressures
Why not contact manufacturer, they know best?
Sent from my iPhone using Tapatalk Pro
Slider09
Re: Tyre pressures
You think? [emoji2]Falconmick wrote:Why not contact manufacturer, they know best?
Falconmick
- Drives: 2019 SE
Re: Tyre pressures
Who else would know better?
Slider09
Re: Tyre pressures
Do you own a VW, much experience of VW dealerships? Seriously, much more knowledge in forums such as these than any dealership.Falconmick wrote:Who else would know better?
If you are new to VW you have yet to discover this. [emoji2]
Re: Tyre pressures
I use that size in winter and stick with the same pressure as the summer 16" wheels/tyres, I see that I've noted that "lightly loaded" for these 15" tyres is 35/32 and comfort is 37/34 though I use the slightly higher pressures of 38/36.
Slider09
Re: Tyre pressures
Thanks [emoji106]Black6c wrote:I put 39 psi front and 36 rear. Even when I had 185/60 R15 and even now with 215/45 R16.Slider09 wrote:1.2 TSI owners - What’s the recommended tyre pressures for the standard 185/60/15 tyres please?
Slider09
Re: Tyre pressures
Thanks [emoji106]RUM4MO wrote:I use that size in winter and stick with the same pressure as the summer 16" wheels/tyres, I see that I've noted that "lightly loaded" for these 15" tyres is 35/32 and comfort is 37/34 though I use the slightly higher pressures of 38/36.
Falconmick
- Drives: 2019 SE
Re: Tyre pressures
Slider, I merely tried to make a helpful reply to your original request and felt that manufacturer would know best. Their figures are the standard. I didn’t/don’t want to get into a sparring match. I have owned around 60 cars, including MK2, MK3 Golf GTi’s,
2 MK7 Golf Rs(manual and DSG), several other VAG cars amongst them all.
All the best.
All the best.
Re: Tyre pressures
That’s VW’s recommended tyre pressure, but IMO it’s not necessarily the optimum tyre pressure for comfort and evenness of tyre wear.Slider09 wrote: Wed Dec 04, 2019 6:54 am 1.2 TSI owners - What’s the recommended tyre pressures for the standard 185/60/15 tyres please?
VW have a habit of recommending quite high tyre pressures - the higher the pressure, the lower the rolling resistance, which may have a positive impact on VW’s published fuel consumption and emissions figures, but it could mean the tyres wear unevenly across the tread width (more wear in the middle of the tread than the outer tread if the pressure is too high).
Some VW’s have a recommended ‘comfort’ tyre pressure for partial load (up to two occupants plus luggage) which is a few psi less than the ‘normal’ recommended pressure. This should also be shown of the sticker inside the fuel filler flap if applicable to your car (usually the second set of figures on the sticker).
Some owners over on golfgtiforum.co.uk run the tyre pressures a couple of psi lower than the recommended figures, so you could try that. You may see a benefit in ride comfort, and IMO any reduction in mpg (if there is any) is likely to be marginal.
Casbantam
- Drives: 1.2 TSI Match
Re: Tyre pressures
I have 215/45/R16 tyres on my 1.2 TSI and listed on various sites it states 28psi all round.
The tyres do look like they need more air in though TBH but usually just me and the Mrs in the car so feels ok.
Who knows best?
Who knows best?
Re: Tyre pressures
I'd expect that MPG and maybe general grip would improve if the pressure was higher than 28PSI at the front, that really is too low considering the axle load the 1.2TSI engine places on the front wheels.
