Driven with oil cap off, please advise
TElwoody
Drives: VW Polo 2018
Post by TElwoody »
Hi all,
My car is a 2018 1.0 95HP Polo SE
I did something stupid and when re filling my oil I forgot to put the oil cap back on (very stupid). After driving for a while I noticed a horrible smell. After opening up the bonnet (hood) I discovered oil had splattered not everywhere but within the vicinity of the cap. It was obviously smoking (hence the smell).
I've wiped up as much as I can, though it still has some to burn off. also the oil temperature reading doesn't seem to be working in the car, is this dangerous, what would everyone advise?
Also if the wire was knocked off for the oil temperature sensor, would anyone know where that is?
giannis159
Drives: polo aw Rline 1.0 115ps
Re: Driven with oil cap off, please advise
Post by giannis159 »
I think sensor is on the bottom.
I agree, the oil level monitoring system module should also be housing the oil temperature.
giannis159
I think that is better to wash your engine in someone special.
Griff74
Post by Griff74 »
If your oil level is still ok I doubt you would have done any harm but I would get your engine bay cleaned down. I did the same thing myself years ago in a Corsa, drove from the Wirral to Manchester before I noticed, apart from some oil splashed around the engine bay and the dip stick showing minimum no harm was done. The oil temp in the Polo takes ages before it shows anything, has to be 50c before it registers and that can be a good while after the coolant is up to temp.
