Hi all,
Does anyone know where the settings are to change the brightness for the light in the little tray where your phone goes that has the charge ports?
light settings for phone tray holder with charge port
POLO Clive
Re: light settings for phone tray holder with charge port
Have you looked in the 'Lights' menu in the Vehicle settings ?
Thanks, I have tried those, but I can't seem to find the one that controls that particular light. Footwell, door and interior don't seem to have any effect on it.
POLO Clive
Not sure then cardiak, I don't have mine yet so it was just an idea. is there a general dimmer/adjuster switch for the main dash/instrument lights ?
I'm sure I changed the brightness on mine at one point. Will have a look later.
silverhairs
- Drives: 2018 Polo SEL
I think it happens when you make the strip below the dash pads brighter, cause in the dark that strip is nice and bright without any distraction.
Cpt_graybeard
- Drives: Polo gti 2018
It is the same as the instrument light.
same as the lightstrip.
Changed mine just the other day
Thanks all. Mines just "off" so I'd wondered if I'd changed it somewhere, I'm guessing there is just a prob with the bulb.
