Dash problems
HGVDave
Drives: 2013 1.4
Dash problems
Post by HGVDave »
We have a 2013 Polo and it has a strange issue - all the dash has stopped working!
No speedo or centre info display included fuel, mpg etc
RPM counter shows it ticking over but doesn’t move if you drive or pump the throttle!
Radio and a/c etc all work just no main dash
Any help would be much appreciated
Re: Dash problems
It may be that the fuse SB11 or SB14 has blown (6R '2013'). One or the other depends on whether your 6R has Bluemotion technology or not.
They are the fuses that are under the steering wheel, are numbered, use a flashlight if necessary.
Whatever the fuse is, it doesn't matter, the important thing is to know why it has blown in case this is the problem.
If this is the case, please check if the headlight range regulation system works.
