Installing Set Tire Pressure button
Hi everybody!! Anybody knows if its possible install the set tire Pressure button in the glove box?
I cant set the tire Pressure because i changed the original radio and i havent got any button in glove box so its impossible for me reset the TPMS...
Thank you!!
Thank you!!
Re: Installing Set Tire Pressure button
I have found this switch... Anyone knows how to install it? And if it will work?
Enviado desde mi MI 9 mediante Tapatalk
Yes, this is the correct button. However, you also need to do some coding of your car. Otherwise, the car doesn't know it has TPMS. I don't know how to do this.
My car is Polo 6C from 2016.iichel wrote:Yes, this is the correct button. However, you also need to do some coding of your car. Otherwise, the car doesn't know it has TPMS. I don't know how to do this.
I had a original radio where i could reset the tpms manually throught menu of radio.
But since i replaced the original radio i cant reset the tpms... So my car supports TPMS via ABS. I dont know if i will need some recoding or just insta the switch because my car supports tpms with the original radio...
I understand. But I think it needs to know that the button is present instead of the radio signal.
I think so too... But i have found who installed the switchz but no idea about recoding...iichel wrote:I understand. But I think it needs to know that the button is present instead of the radio signal.
I have a Vagcom wire i dont know if with vagcom i could recoding it...
I have found this scheme... Anyone can explain me a little? Its valid for a Polo 6C?
I am looking for a assembly scheme or instructions but i dont have found it yet.
My mechanic request me the assembly scheme to install the button....
Anyone could help me??
You can show this to your mechanic, I think then he'll know how to make the wiring
There isnt step by step manual? My mechanic cant read this scheme.iichel wrote:You can show this to your mechanic, I think then he'll know how to make the wiring
He told me that this scheme is for VW technicians... He needs a manual of installation.
Any help? Please
giannis20vt
I am planning to the same to my 6c Polo.
As a matter of act, i will install 2 buttons, one for the TPMS and one for the TCS.
I don't think is going to be a hard or a difficult install. All I am interested in is the wiring through the ABS unit. How i am suppose to drive the wires (one for TCS and one for TPMS) to the engine compartment ? Any ideas or suggestions ?
