location of major earthing points
Greetings All. So I have this ongoing stalling problem from cold with my 1.4 BKY (see my previous car stalling post). After changing sensors all over the car I am about to carry out a vacuum test with a smoke machine. If that proves faultless I wanted to check all the earthing points arounf the engine bay before packing my ECU of to the ECU doctor for testing. Could anyone direct me to the right locations for checking earthing points on the 9n 1.4 petrol?
Re: location of major earthing points
I believe that they are all listed in the workshop manual for this model of Polo - this you can get access to via Erwin though you will need to register to use that site and there is an hourly user rate which allows you to grab (download) the entire contents for your car within that hour period.
Thanks RUM4MO
littlepolo
Did you get hold of information about earthing points?
Yes thanks littlepolo.
