Re: Patil's 6R RHD Ambient lights my way:)
Hello friends, Namaste:)
Sharing with you all, my new mod, Ambient lights in my Polo6R.
Special thanks to Master ciclo, his ambient lighting mod was an inspiration.
Previously....
viewtopic.php?f=56&t=73189&start=105
Only pictures for now, full details will share later.
Previously....
- ag69
- Drives: 1.2TSi 77Kw 7DSG
Very nice!!!
you also got all switches in dashboard to illuminate? or you have actual functioning switches?
hmm... is a hoot.
I guess the camera increases the brightness and sharpness of the red color in these shots.
Thank you for your kind appreciation.
Yes all dash buttons are illuminating. Only heated seat buttons(for now) are non functional, rest all are functional.
Used Start/Stop button for ON/OFF function of ambient lights.
I've prepared a pcb circuit with special relay and positive voltage regulator to convert push button signal into continuous signal with on/off functionality.
For new module I've given +15 supply from fusebox(1A, fused). The circuit is normally closed, so it works like this.. ambient lights will turn on by default with turning on sidelights/ or light sensor activation in dark.
The ambient lights then can be manually turned OFF and ON again and so on with dash button(works only with ignition ON).
So far so good.
Aye Master you are absolutely right!... in reality the illumination is around 60 percent of what you see in pictures.
My photography skill sucks, and same goes with my smartphone camera quality.
Made a short video clip of ambient lights with dash button in action, illumination is almost real, hope you can appreciate it better.
- Drives: 1.2TSI 105HP DSG7
Re: Patil's 6R RHD Ambient lights my way[emoji3]
thats interesting. can we have a look and more information on the special module? would to see n to have that made as wellpatil wrote:Thank you for your kind appreciation.
So far so good.
Great! Thanks for the video.patil wrote: ↑Wed Feb 12, 2020 10:26 am Made a short video clip of ambient lights with dash button in action, illumination is almost real, hope you can appreciate it better.
https://www.youtube.com/watch?v=9VTxvWyZhQg
Nice melody, it seems that your sound system sounds great.
Hello benzinkopf,benzinkopf wrote: ↑Wed Feb 12, 2020 2:42 pm
Surely I will post all details with pictures, soon.
Thanks.
Thank you for your appreciation Master, means a lot to me.ciclo wrote: ↑Thu Feb 13, 2020 2:44 amGreat! Thanks for the video.patil wrote: ↑Wed Feb 12, 2020 10:26 am Made a short video clip of ambient lights with dash button in action, illumination is almost real, hope you can appreciate it better.
The song played was old 70's Indian classic.
The sound system is comprised of stock speakers, and I've installed OEM tweeters front Apillars and C pillars in the back.
The Discover media sound processing is simply awesome to say the least, I never thought the stock paper cone speakers are so capable, underestimated them until I installed Discover media.
Yes, I appreciated the same on the standard speakers when I installed the Subwoofer with the AMP (Helix-VW).
Magic sound ...
I also noticed a great evolution of sound with the new Headunits in my most recent cars. In both Discover and Composition Media.
Magic sound ...
very nice ! does not itself obstruct such light?
- Cesaree_VWR
- Drives: 2010 Polo 6r 1.4 MPI
Can you pls send some pics of the actual LEDs you've used and the way you fited them to the door cards etc? Can't figure out how to do this and make it look pretty too...
Here you go... pulled out the pictures from archive for you
The above led's are 12v flat head bolt type bought from Aliexpress.
