Obd reader / prog
CLIFFORD2K1
- Drives: 1.0 115 sel dsg
Obd reader / prog
Hi all. What are people using to read obd codes? Know about vcds but this seems an an expensive option for the official lead and software. Also obdeleven seems abit of a faff with credits etc for coding. What do people recommend to use?
Re: Obd reader / prog
If it is only fault codes you intend to read, then Carista is okay, I can't comment on the current pricing/access model as I've had mine too long to have to pay extra to make fuller use of it, but have you looked into OBDeleven pricing if you only want to read/clear fault codes - again I have never looked into that one as I am mainly a VCDS user.
