Hi Guys,
I am from the Netherlands and i have a VW Polo 6R 2010 model.
1.2 TDi CFW engine Left hand drive.
I recently changed the cluster and ecu, and now i am having problem with the long coding of the abs module.
I have like a christmas tree on my cluster, almost every light is on
Can someone help me with the long code?
i now have only 00000000000000000000000 on the screen.
Cheers Lakerbas
ABS Long coding issue
Re: ABS Long coding issue
Post a full scan please with advanced ID's of the immo and the ECU
Hi all I am new on this forum I have lost ABS long code of polo 1.2 , 2010 VIN no: WVWZZZ6RZAU000718, VAG NUMBER; 6R0907379R, SYSTEM DESIGNATION BOSCH ABS/ ESP 8.2i , SOFTWARE VERSION 0002.
I wonder if someone can help me
Thanks I will send you
Here is my car's scan, I couldn't find the option 'to attach my word document, therefore, I pasted the scan if I Have done wrong apologies.
Tuesday,10,March,2020,18:06:42:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 16.8.3.1
Data version: 20161010 DS267.0
www.Ross-Tech.com
VIN: WVWZZZ6RZAU027976 License Plate:
Chassis Type: 6R (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ6RZAU027976 Mileage: 96440km-59925miles
Address 01: Engine (CGP) Labels: 03E-906-033-AZQ.lbl
Part No SW: 03E 906 023 AL HW: 03E 906 023 L
Component: SIMOS91 1.2l 4V 4523
Revision: --H04--- Serial number:
Coding: 0000031
Shop #: WSC 31414 790 31414
VCID: 69DE66E643E2A20A0B-5040
4 Faults Found:
17523 - Oxygen (Lambda) Sensor Heating: B1 S1
P1115 - 007 - Short to Ground
RPM: 960 /min
Mass Air / Rev.: 125.4 mg/str
Voltage: 0.580 V
Voltage: 13.67 V
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2
P1117 - 007 - Short to Ground
RPM: 960 /min
Voltage: 0.500 V
Voltage: 13.67 V
17549 - Load Calculation Cross Check
P1141 - 007 - Implausible Value - Intermittent
Lambda: 38.7 %
Lambda: -37.1 %
Lambda: 36.7 %
T.B. Angle: 7.0°
Lambda: 48.0 %
Lambda: -37.1 %
Lambda: 36.7 %
T.B. Angle: 3.8°
18010 - Power Supply Terminal 30
P1602 - 008 - Voltage too Low - Intermittent
Voltage: 6.94 V
Bin. Bits: 00000100
RPM: 960 /min
Temperature: 13.5°C
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 R HW: 6R0 907 379 R
Component: ESP8.2i front H04 0002
Revision: --------
Coding: 000000000000000000000000000000000000
VCID: 4D96B276104A5E2A07-8018
3 Faults Found:
01042 - Control Module; Not Coded
000 - -
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 13
Reset counter: 92
Mileage: 96447 km
Time Indication: 0
Date: 2045.14.22
Time: 00:41:04
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1213
Hex Value: 0x149A
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
03306 - Coding Not Valid
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 132
Mileage: 96447 km
Time Indication: 0
Date: 2045.14.22
Time: 23:47:01
Hex Value: 0x0003
Hex Value: 0x0002
Hex Value: 0x32E7
Hex Value: 0x2596
Hex Value: 0x0085
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
00532 - Supply Voltage B+
002 - Lower Limit Exceeded
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 4
Reset counter: 92
Mileage: 96447 km
Time Indication: 0
Date: 2045.14.22
Time: 23:57:30
Hex Value: 0x0003
Hex Value: 0x0003
Hex Value: 0x3224
Hex Value: 0x0370
Hex Value: 0x0085
Hex Value: 0x7F7F
Hex Value: 0x7E00
Hex Value: 0x0000
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 D HW: 6R0 937 087 D
Component: BCM PQ25 H+4 H46 0207
Revision: BF046001 Serial number: 0147 339090784
Coding: 24B02BBF08A10000003000003D2B0CD00040410F60060000200000000000
VCID: 3E74E5BAA9ECF5B28E-806A
4 Faults Found:
00975 - Heated Rear Window (Z1)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 90
Mileage: 96447 km
Time Indication: 0
Date: 2045.14.07
Time: 01:30:13
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 3
Reset counter: 92
Mileage: 96447 km
Time Indication: 0
Date: 2045.14.23
Time: 00:22:10
00446 - Function Limitation due to Under-Voltage
Fault Priority: 6
Fault Frequency: 7
Reset counter: 92
Mileage: 96447 km
Time Indication: 0
Date: 2045.14.22
Time: 23:58:05
01117 - Generator Terminal DF Load Signal
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 92
Mileage: 96447 km
Time Indication: 0
Date: 2045.14.22
Time: 00:38:46
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag00E H09 0018
Revision: -------- Serial number: 003DW0044TLK
Coding: 003045
VCID: 428C914AD5149152EA-8016
Serial number: 3572SRB400008E5CCB2M
Serial number: 3582SRB400009988E1BJ
Serial number: 3516GRB402J968JOOC3R
Serial number: 3526GRB402D968JOUKD3
5 Faults Found:
9437723 - Igniter for Passenger's Airbag
B1002 1B [137] - Resistance Too High
9438747 - Igniter for Seat Belt Tensioner; Driver's Side
B1006 1B [137] - Resistance Too High
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 96447 km
Date: 2109.14.07
Time: 01:30:16
9438976 - Igniter for Seat Belt Tensioner; Passenger's Side
B1007 00 [000] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
0000 - Internal Control Module Memory Check Sum Error
B2000 00 [000] - -
Fault Priority: 1
Fault Frequency: 254
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
B2000 00 [000] - -
Fault Priority: 1
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 960 D HW: 6R0 920 960 D
Component: KOMBI H03 0205
Coding: 440000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
VCID: 3664FD9A89DC3DF256-8062
2 Faults Found:
9453842 - Oil Level Thermal Sensor
B1041 35 [009] - Signal high time > maximum
Fault Priority: 2
Fault Frequency: 1
Reset counter: 90
Mileage: 96447 km
Date: 2020.02.20
Time: 01:30:16
13635840 - Supply voltage
U1011 00 [009] - Voltage too Low
Fault Priority: 6
Fault Frequency: 3
Reset counter: 92
Mileage: 96447 km
Date: 2020.03.07
Time: 00:22:37
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087 D
Component: GW-K-CAN TP20 0207
Coding: 002300
VCID: 70E80B82A33853C24C-8024
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H03 0205
Serial number:
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
VCID: 6ADC19EA8DE4A91202-803E
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10150
Shop #: WSC 31414
VCID: 2E54D5FAED8C05321E-807A
1 Fault Found:
01288 - Terminal 30; Steering Assist
07-10 - Signal too Low - Intermittent
Address 56: Radio Labels: None
VCID: 55A65A16BC9A16EABF-FFFE
End-------------------------(Elapsed Time: 07:00)--------------------------
www.Ross-Tech.com
Coding: 0000031
4 Faults Found:
RPM: 960 /min
Voltage: 0.580 V
Voltage: 13.67 V
RPM: 960 /min
Voltage: 0.500 V
Voltage: 13.67 V
Lambda: 38.7 %
Lambda: -37.1 %
Lambda: 36.7 %
T.B. Angle: 7.0°
Lambda: 48.0 %
Lambda: -37.1 %
Lambda: 36.7 %
T.B. Angle: 3.8°
Voltage: 6.94 V
Bin. Bits: 00000100
RPM: 960 /min
Temperature: 13.5°C
Readiness: N/A
Revision: --------
3 Faults Found:
000 - -
Fault Priority: 0
Fault Frequency: 13
Reset counter: 92
Mileage: 96447 km
Time Indication: 0
Date: 2045.14.22
Time: 00:41:04
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1213
Hex Value: 0x149A
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 132
Mileage: 96447 km
Time Indication: 0
Date: 2045.14.22
Time: 23:47:01
Hex Value: 0x0003
Hex Value: 0x0002
Hex Value: 0x32E7
Hex Value: 0x2596
Hex Value: 0x0085
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
Fault Priority: 0
Fault Frequency: 4
Reset counter: 92
Mileage: 96447 km
Time Indication: 0
Date: 2045.14.22
Time: 23:57:30
Hex Value: 0x0003
Hex Value: 0x0003
Hex Value: 0x3224
Hex Value: 0x0370
Hex Value: 0x0085
Hex Value: 0x7F7F
Hex Value: 0x7E00
Hex Value: 0x0000
4 Faults Found:
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 90
Mileage: 96447 km
Time Indication: 0
Date: 2045.14.07
Time: 01:30:13
Fault Priority: 3
Fault Frequency: 3
Reset counter: 92
Mileage: 96447 km
Time Indication: 0
Date: 2045.14.23
Time: 00:22:10
Fault Priority: 6
Fault Frequency: 7
Reset counter: 92
Mileage: 96447 km
Time Indication: 0
Date: 2045.14.22
Time: 23:58:05
Fault Priority: 3
Fault Frequency: 2
Reset counter: 92
Mileage: 96447 km
Time Indication: 0
Date: 2045.14.22
Time: 00:38:46
Coding: 003045
5 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Mileage: 96447 km
Date: 2109.14.07
Time: 01:30:16
B1007 00 [000] - -
B2000 00 [000] - -
Fault Priority: 1
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
B2000 00 [000] - -
Fault Priority: 1
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Coding: 440000
2 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 90
Mileage: 96447 km
Date: 2020.02.20
Time: 01:30:16
Fault Priority: 6
Fault Frequency: 3
Reset counter: 92
Mileage: 96447 km
Date: 2020.03.07
Time: 00:22:37
Coding: 002300
Serial number:
Coding: 10150
Shop #: WSC 31414
1 Fault Found:
Give this a try please
230224E3216F00B9C42E24E984D700801700
Well done it did work on the first attempt many thanks, you are an asset to this group
Thanks for the feedback
