The overflow drain is blocked and not draining. Never overfilled with fuel so only found out while washing the car as a pool would sit and not drain as it should. I’ve tried letting some surfex HD sit in there to no avail and then some Tardis again which didn’t work. I’m guessing there’s a pipe there. Is there anyway to get it out so I can give it a good clean?
Another small issue is the fact that the fuel door and filler cap don’t lock. Car doesn’t have any central locking so the filler cap has a key lock. No matter if it’s locked or unlocked I can unscrew it with no resistance.
The fuel door also pops open and shuts as it should, however I can open the door without popping it open by just simply pulling at the gap around it and the button still stay pressed in. I occasionally notice that it’s slightly ajar after a couple days of driving.
Again not massive issues would just like to fix them and can’t find much about them.
Any help would be much appreciated
