Brake Upgrade
Craig 6r
Drives: 6r polo 1.4 gti
Brake Upgrade
Post by Craig 6r »
Hi...I have a 2011 Polo Gti 1.4 Twincharge with stage 1 and was thinking about upgrading to 312mm discs...can I use my 288mm caliper with a 312mm Carrier or should I just put some Brembo max grooves discs on instead.....thanks for any help...
Re: Brake Upgrade
Yes certainly you can. But there is a catch, you'll have to code your ABS in such a way that it can distribute the braking force evenly between the front and the rear.
Craig 6r
Re: Brake Upgrade
Post by Craig 6r »
Thanks for the advice...I’m probably go with Brembo max discs with Brembo xtra pads...£150 from Eurocarparts....
Re: Brake Upgrade
For non gti model for bigger brake setup (288) I would have to upgrade to new hubs? and ofc. caliper carriers discs, pads, and caliper?
Marko106
Drives: 6R 1.6
Re: Brake Upgrade
Post by Marko106 »
amer6R wrote: Thu Apr 16, 2020 10:41 am For non gti model for bigger brake setup (288) I would have to upgrade to new hubs? and ofc. caliper carriers discs, pads, and caliper?
If you have the 256mm and want to put 288 and 310 you must replace the hubs. If you have the 288 you can install the 310mm brake with only replace disc and calipers
Re: Brake Upgrade
288 -> 312 no problem
256 -> 288 you need to change hubs
256 -> 312 you need to change hubs
288 and 312mm hubs are the same
Re: Brake Upgrade
I think I accidentally locked the topic. Sorry about that
Marko106
Drives: 6R 1.6
Re: Brake Upgrade
Post by Marko106 »
iichel wrote: Thu Apr 16, 2020 12:49 pm 288 -> 312 no problem
I’ve buyed the 310mm brake caliper of gti 6c and original are marked to use with the 310mm disc. But zimmerman don’t produce sport disc for the 310mm. I’ve buyed the disc from ibiza cupra 160hp 312mm and fit perfect on that caliper.
Re: Brake Upgrade
Same for me, I got the 312mm discs for Audi S1 2.0 TFSI. Fits perfectly.
Re: Brake Upgrade
Pocket rockets!
Sent from my Nokia 6.1 Plus using Tapatalk
