I want to correct my speedo to avoid any tickets, currently im running 205/40/17 tire size
I saw there were some coding options for this in cluster ( named like for fabia and etc.)
Does someone know how to calculate this and what is the closer option for 205/40/17 tire?
Sent from my Nokia 6.1 Plus using Tapatalk
Distance impulse number
spacewalker
- Drives: Just a VW
Re: Distance impulse number
that coding is a "ratio" what VW made
start code and check if speed show correct
I know, but I dont know what dimension / ratio is closest to the one i have
