Rear Light Trouble
joe.rigby
Drives: Polo GTI
Rear Light Trouble
Post by joe.rigby »
Hello, I have just disconnected and then reconnected my left rear light on my Polo 6R GTI. After reconnecting, the light bulb warning has come up on the cluster and the left light isn’t working. The brake, reverse and indicator lights still work on it. Has anyone got and solutions? Cheers.
Re: Rear Light Trouble
check if the connector is properly seated and whether there is anything rattling inside your tail light.
joe.rigby
Drives: Polo GTI
Post by joe.rigby »
The connector is properly seated and the light doesn’t rattle. Could removing it have caused a bulb or fuse to go?
alit
Drives: VW Polo 2011 6R1
Post by alit »
I have a similar problem with my Polo 2011 6R1. The Light warning light is on on the dashboard and it seems that one of the reverse light is not working. I changed the bulb and still, the light would not come on in reverse and get the warning on the dashboard. Could this be a fuse issue or short circuit somewhere?
Dink
Drives: 2015 GTI
Post by Dink »
alit wrote: Thu Jun 11, 2020 11:06 pm I have a similar problem with my Polo 2011 6R1. The Light warning light is on on the dashboard and it seems that one of the reverse light is not working. I changed the bulb and still, the light would not come on in reverse and get the warning on the dashboard. Could this be a fuse issue or short circuit somewhere?
the polo only has one reversing light.
alit
Post by alit »
why is there two bulbs located in the same location one on left and one on the right side.
Pierlu
Drives: Polo MY2015 1.2 TSI
Post by Pierlu »
alit wrote: Fri Jun 12, 2020 2:58 pm why is there two bulbs located in the same location one on left and one on the right side.
On the left there is the rear fog light and on the right the reverse light
d-ash
Drives: 6C 2016 R-Line 1.2 90PS - Blue Silk
Post by d-ash »
In the UK, reverse light on the left and rear fog on the right :wink:
alit
Post by alit »
That explains it
