Hi there, my parters polo (2015 1.4 tdi) tyre pressure light keeps illuminating. I have checked pressures all are fine, been on for 6 months now. It doesnt have sensors in the wheels so presume it uses the abs. Anyway to tell which tyre it is ect?
Thanks steve
Tyre pressure light
Steve11115
- Drives: Mk 5 1.4 tdi
Re: Tyre pressure light
Maybe you just need to reset the sensors. Either there is a button in the glove box or access it via the CAR menu on the radio head unit.
Steve11115
Have reset loads of times just keep coming on a couple of minutes later
govindsharma
- Drives: polo 1.2 petrol HighLine
Is there any error in abs module in VCDS ? I have also same problem but it is solved by cleaning throttle body .What i understand from my car error i am getting error in engine which taken over by ABS unit and tire pressure lights glows but when ESP installed in same error ESP and tire pressure light glows.At last i diagnose it with Odis and found that there is error in throttle body which cause this error and finally by cleaning throttle body all error gone.And all works well.Its my opinion only.
Thank you.
Thank you.
Steve11115
Thanks for the reply,i havnt got vcds, ive used a code reader and no codes came up
Bent wheel?
