Safelock
J+silva
Drives: polo conf.
Safelock
Post by J+silva »
Hi does anyone know if it is possible to activate the safe-lock with obdeleven or is it necessary to install some mechanism?
OomStu_ZA
Drives: 2019 VW Polo GTi
Re: Safelock
Post by OomStu_ZA »
Is safe lock not standard across the range?
http://www.vwpolo.net/safelock_mechanis ... %20locked.
Dazeredo
Drives: Polo aw1 1.0t 95hp
Re: Safelock
Post by Dazeredo »
I think that is a bundle with the alarm... At least in Portugal the alarm option also included the description of the safelock.
J+silva
Drives: polo conf.
Re: Safelock
Post by J+silva »
I think not there is no info. Safe lock in the display and it is possible in my car to open the doors inside, and I press the command button 1 time only.
Enviado do meu SM-A405FN através do Tapatalk
J+silva
Drives: polo conf.
Re: Safelock
Post by J+silva »
Do you know if it is necessary to install any component or even an alarm? I still haven't found information on the net to see if it is possible to activate the safe lock.
Dazeredo
Re: Safelock
Post by Dazeredo »
I don't know for sure what needed. For the OEM probably it needs, besides the equipment installation, to change some parameter in the car computer. An aftermarket alarm can talk to the car computer but I doubt that would activate the safelock.
Because of the problems I had with the aftermarket alarm I had in the previous car (installed by the dealership) I paid to have the factory alarm without second thought.
The alarm, parking sensors and camera where extras that need to come from factory to avoid all the problems I had before :oops:
