Small fan running after switching engine off
Steve_2019
Drives: VW Polo SEL DSG 2019
Post by Steve_2019 »
Anyone noticed a small fan running after switching the engine off on the 1ltr engine. It definitely not the coolant fan it’s not that noisy.
Re: Small fan running after switching engine off
Same thing happens with the GTI. Think it stops after around 5 minutes. :)
Steve_2019
When I had a peogeot on there engines there is a pump pumping coolant around the turbo to cool it down after you turn the engine off wonder if it’s a same kind of thing with the VW engines.
It’ll be an auxiliary electric pump running that’s used for cooling down the turbo. Normal and nothing to worry about.
