Clunking noise when changing gears.
LeebzP
Drives: 1.0 TSI R-Line - Energetic Orange
Post by LeebzP »
Hi guys.
Has anyone experienced a clunking noise when changing gears? I have a 1.0 tsi manual rline. Upon browsing, I've read that it could be related to some mountings. I also suspect the rattling noise upon acceleration is related.
I took it to VW the last service and I was told it's just normal. The next service is coming soon and I'm taking it to a different dealer to confirm.
Please advise.
The Random Dan
Drives: GTI+
Re: Clunking noise when changing gears.
Post by The Random Dan »
I have a GTI with DSG and mine clunks sometimes at low revs when im manual shifting, sounds like engine mounts or CV joints taking up slack
Also if I accelerate from too low revs in too high gear I get a rattle like the whole transmission is rattling. Mines only 4 months old and done 2,000 miles
LeebzP
Post by LeebzP »
The Random Dan wrote: Wed Jul 01, 2020 6:44 pm I have a GTI with DSG and mine clunks sometimes at low revs when im manual shifting, sounds like engine mounts or CV joints taking up slack
Although we've got different engines, I do think we have the exact same issue indeed.
roakley
Drives: GTI Plus
Post by roakley »
That means it's 'pinking' - not a good thing to do!
roakley
Drives: GTI Plus
Post by roakley »
roakley wrote: Wed Jul 01, 2020 9:06 pm
Pinking" is very bad and can permanently damage the internals of the engine
The Random Dan
Drives: GTI+
Don’t do it often, sometimes just try to accelerate in too higher gear and have to change down
The Random Dan
Drives: GTI+
Steve_2019
Drives: VW Polo SEL DSG 2019
Post by Steve_2019 »
I sometimes get clucking when I’m putting my DSG in too park from drive.
The Random Dan wrote: Wed Jul 01, 2020 9:16 pm
Are you in full manual mode when you do this? Surely if the car is in D or S mode, the DSG box will knock down through the gears if you try to labour the engine by putting your foot down in something like 4th at 1200rpm? Or do you get that rattle/shudder initially only while the car waits to drop a gear or 2?
The Random Dan
Drives: GTI+
monkeyhanger wrote: Thu Jul 02, 2020 6:04 am
Yes in full manual Mode, it doesn’t sound like engine pinking, its like a shudder in the drivetrain
You're labouring the engine if you put your foot down in a high gear at low rpm, well below the turbo spooling threshold of about 1800rpm. Its normal for the drivetrain to do that under those circumstances.
Labouring the engine is not something I'd recommend doing.
The Random Dan
Drives: GTI+
I am aware its normal, just confirming to the OP that mine makes the same noises.
Like I said I don’t make a habit of doing it, its just those instances when you think “I’ll see if i can overtake this cyclist without having to change down” but you end up having to anyway.
90% of the time its just in normal D mode
Simonz
Drives: 2023 Life TSI
Post by Simonz »
I have noticed the same noise, a clunking sound mainly at low speeds when changing from first to second and then second to third. I think it's normal, a 'characteristic' of the vehicle. It's the differential having a bit of movement and taking up the slack in the gears. If you drive carefully you can eliminate it, but just let the clutch out a bit carelessly you hear the clonk. I think this may have been raised by VW Up! owners a while back, not helped by the gearbox having a thin casing (cost cutting again). If it's any help I had the same noise on my previous Fiesta Zetec, as well as a terrible graunching sound as you put a load on the gearbox from low speed - suspect that was the layshaft bearing. Gearboxes are tough though, probably will run for 100k with the noise it' just very irritating. Makes you want to buy an automatic... :roll:
Happens with my previous generation Polo GTI with manual gearbox when changing from 1st to 2nd. It’s been like that from new and the car’s now 4 years 4 months old. Gear change is very smooth and the clunking noise hasn’t got any worse since new.
Simonz wrote: Thu Jul 02, 2020 10:31 am I think this may have been raised by VW Up! owners a while back, not helped by the gearbox having a thin casing (cost cutting again).
It's not "cost cutting", it's "weight saving" :lol:
Cost cutting wouldn't be quite so bad if the cutting back didn't coincide with inflation busting price rises.
