Do I have one touch windows?
TheRacingRat
Drives: 2020 Polo GTI+
Post by TheRacingRat »
Should my front electric windows go up or down with one touch? It doesn’t seem to at the Moment?
Re: Do I have one touch windows?
You should have. They may need resetting;
https://www.vwgenuineparts.co.uk/vw_aut ... tion.shtml
TheRacingRat
So I’ve done the reset thing and both front windows still only go up or down if you keep your finger in the button.As soon a you take your finger off the window stops. Confused??
TheRacingRat wrote: Mon Jul 13, 2020 4:49 pm So I’ve done the reset thing and both front windows still only go up or down if you keep your finger in the button.As soon a you take your finger off the window stops. Confused??
Is this with the ignition on or off? One touch only works with the ignition on, and only then on the front door switches. Does your switch feel 2-stage? Can you push past first click to a second?
TheRacingRat
Yes that works! You have to press it to its 2nd stage to activate the one touch. Apologies for my stupidity. Blame it on the heat. Thank you Mr Hanger.
Dark_cze
Drives: AW GTI with MT
Post by Dark_cze »
monkeyhanger wrote: Mon Jul 13, 2020 5:19 pm
I have one touch working on all switches at every door. :) I guess it is enabled in some countries. :)
foolhandy
Drives: 9N
Post by foolhandy »
SRGTD wrote: Sun Jul 12, 2020 7:33 pm You should have. They may need resetting;
This is brilliant! Thank you! 8)
