Hey all
This morning started the car it beeped and the ABS light stayed on with the handbrake light flashing. Brakes still work fine. Any ideas what this could be?
Abs light on with flashing brake light symbol
- normanharrop
Re: Abs light on with flashing brake light symbol
Just about anything related to the ESP or ABS system really.
- normanharrop
Ok thanks is there like any common faults I can try to fix to solve the problem??
You really should get this car scanned with a suitable fully VW Group compliant scan tool to minimise the possibility of you wasting money, without doing that you are just guessing, with it you should get some idea of what the system thinks is wrong.
- normanharrop
Guys this evening I have put a odb diagnostic tool on it and came up with no codes and checked the brake fluid and seems full still any ideas??
