Problem with A/C Humidity Sensor (G260) (and others)
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
For a long time I've had some errors on my Polo and now it's time to figure out why...
1) Address 08: Auto HVAC (J255) says there is an error. Looking in Address 09: Cent. Elect. (J519) it's because of the "A/C Humidity Sensor (G260)". However the BCM fully recognizes it:
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 150415 03  37  0059
   Coding: 0788DD
Why ??
2) Address 10: Park/Steer Assist (J446) with unknown error.
VCDS says nothing - VCP says it's a missing databus message. What dataset could I've use to fix this error? It works as it should, I'm just trying to figure out how to get rid of this error.
3) Address 55: Headlight Range (J431)
ciclo module:
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   Shop #: WSC 00788 648 00255
   VCID: 77AB16A00F4AAFDFAF7-8022
my module
   Coding: 0392000001000000
   Shop #: WSC 00066 123 12345
   VCID: 77ABE9E9EF480523628-8022
Why the fu... can't I've code it as a Polo module? It's the first bytes that is rejected in VCDS... Still it works - I'm just wondering...
4) Address 61: Battery Regul.
Any idea what the correct coding should be ?
I know that there are errors regarding reverse camera and some other stuff in 09.. That I just need to fix at some point ;) (this weekend)
Complete log:
Wednesday,12,August,2020,19:55:43:21529
VCDS Version: 20.4.0.1 (x64)  HEX-V2 CB: 0.4508.4
www.Ross-Tech.com
VIN: WVWZZZ6RZBY118xxx   License Plate: POLO
Mileage: 159630km-99189mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 37 44 55 56 5F 61 77
VIN: WVWZZZ6RZBY118xxx   Mileage: 159630km-99189miles
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 EP    HW: 03L 906 023 D
   Component: R4 1.6l TDI   H13 9979
   Revision: --H13---    Serial number:
   Coding: 00114016002401080000
   ASAM Dataset: EV_ECM16TDI02103L906023EP 003012
   ROD: EV_ECM16TDI02103L906023EP_003.rod
   VCID: 78A9EAD5E2560A5B6B2-802C
1 Fault Found:
7196 - Function Restriction due to Faults in Other Modules
          U1113 00 [100] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 10
                    Mileage: 159480 km
                    Date: 2020.07.26
                    Time: 23:23:33
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 37 °C
                    Intake air temperature: 21 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 11.407 V
                    Unlearning counter according OBD: 31
                    Engine speed: 0 /min
                    Accelerator position: normalized-Accelerator position: 0.00 %
                    Battery voltage: 11.3 V
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AJ    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3416E00BA842D14E282D500521300
   VCID: 0655942D98626CAB69E-8052
1 Fault Found:
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 26
                    Reset counter: 4
                    Mileage: 159504 km
                    Time Indication: 0
                    Date: 2014.12.31
                    Time: 14:13:54
                    Hex Value: 0x4007
                    Hex Value: 0x0000
                    Hex Value: 0x3203
                    Hex Value: 0x2B9A
                    Hex Value: 0x008A
                    Hex Value: 0x7F7E
                    Hex Value: 0x8016
   Part No SW: 6R0 907 044 B    HW: 6R0 907 044 B
   Component: Climatronic   H08 0305
   Revision: V0000000
   VCID: 323D18FD442A200B956-8066
2 Faults Found:
00457 - Central Electronics Control Module / BCM (J519)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 4
                    Mileage: 159500 km
                    Time Indication: 0
                    Date: 2014.12.31
                    Time: 00:30:10
01314 - Engine Control Module
                    Fault Status: 00100100
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 44
                    Mileage: 159504 km
                    Time Indication: 0
                    Date: 2014.12.31
                    Time: 14:03:46
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 316153256
   Coding: 3CB02FBF682B000021380FD17DEB9FD8DAC067AF608D70D0200400030800
   Shop #: WSC 00046 123 12345
   VCID: 6889BA95B2769ADBFB2-803C
   Coding: 0788DD
   Subsystem 2 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0903
   Serial number: KU0-KU027.09.1014111
   Coding: 58BC30
   Subsystem 3 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0902
   Serial number: KU0-KU023.09.1012131
   Coding: 48BC30
   Subsystem 4 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 29150000228280105063
   Coding: A4FFFF
   Subsystem 5 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
   Component: J388__TSG_HL  006 0902
   Serial number: KU0-KU021.09.1015081
   Coding: 48BC32
   Subsystem 6 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
   Component: J389__TSG_HR  006 0902
   Serial number: KU0-KU020.09.1011045
   Coding: 48BC32
3 Faults Found:
            011 - Open Circuit - Intermittent
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 36
                    Time Indication: 0
03156 - Sensor for Anti-Theft System (G578)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 251
                    Mileage: 159500 km
                    Time Indication: 0
                    Date: 2014.12.31
                    Time: 00:36:33
01229 - A/C Humidity Sensor (G260)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 251
                    Mileage: 159500 km
                    Time Indication: 0
                    Date: 2014.12.31
                    Time: 00:29:37
Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331427504547
   Coding: 0071150041
   Shop #: WSC 05311 115 00317
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: N/A
   VCID: 372B29E9AFC8C523A28-8062
No ASAM data for: "EV_EPHVA18VW364GP00" (VW25)
1 Fault Found:
12718592 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 250
                    Mileage: 159480 km
                    Date: 2020.07.26
                    Time: 23:23:30
   Part No SW: 6R0 959 655 L    HW: 6R0 959 655 L
   Component: VW10Airbag00G H09 0020
   Revision: --------    Serial number: 003GY001782S
   Coding: 003047
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4BC36519C34051C3F60-801E
   Serial number: 3572SRB40000CA24E279
   Serial number: 3582SRB40000CA24A8CH
   Serial number: 3515RRB406301NFS7HHS
   Serial number: 3525RRB405L010DAB8D.
   Part No SW: 5JA 920 840 E    HW: 5JA 920 840 E
   Component: KOMBI         H04 0709
   Coding: 111A00
   Shop #: WSC 73430 031 00007
   VCID: 3C2136C596EEE67B4FA-8068
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 002205
   Part No SW: 7E0 857 511 E    HW: 7E0 857 511 E
   Component: FLA           H09 0002
   Revision: AA001001
   Coding: 040400E200000000000000
   Shop #: WSC 02739 790 50316
   VCID: 2C010685668E76FBDFA-8078
   Component: IMMO          H04 0709
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6A8DC09DACFAA8CBED6-803E
Address 37: Navigation
Cannot be reached
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F3B11895E580DE3FA8-807A
Address 56: Radio
Cannot be reached
   Part No SW: 5C0 035 680 F    HW: 5C0 035 680 F
   Component: MU-S-N-ER     H41 0478
   Serial number: VWZAZ2W0961022
   Coding: 02620001FF0000000111000100080A001F0100D4002001008F
   Shop #: WSC 00020 999 12345
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 2411EEA50E5EBEBB17A-8070
   Data medium:
   Subsystem 1 - Part No SW: 5NA 919 866 AR    HW: -----------
   Component: ECE AS 20/21  --- 1430
4 Faults Found:
1556 - Internal Control Module Memory Check Sum Error
          B2000 87 [009] - Missing message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 250
                    Mileage: 159481 km
                    Date: 2020.07.26
                    Time: 00:01:11
                    Voltage terminal 30: 13.0 V
                    System_Software_Error-SW_Status_Consistency: 06 02 00
                    System_Software_Error-SW_Status_Device: B
15360256 - Component Protection
          U1101 00 [009] - Active
          [Anti-theft protection - component protection active (0xEA6100)]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 250
                    Mileage: 159480 km
                    Date: 2020.07.26
                    Time: 23:23:30
                    Voltage terminal 30: 11.5 V
6720 - Rear View Camera
          B1102 31 [008] - No Signal
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 42
                    Mileage: 159588 km
                    Date: 2020.08.11
                    Time: 15:18:09
                    Voltage terminal 30: 13.8 V
0003 - Antenna 2 for radio
          B111A 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 250
                    Mileage: 159480 km
                    Date: 2020.07.26
                    Time: 23:23:30
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 0 dBµV
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0733
   Coding: F1001873
   Shop #: WSC 12345 123 12345
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790056213
1 Fault Found:
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2014.12.31
                    Time: 13:48:23
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 01:35, VBatt start/end: 12.2V/12.2V)-----------
Re: Problem with A/C Humidity Sensor (G260) (and others)
Regarding humidity sensor, I'm not sure your sensor has humidity sensing.
This is yours:
Coding: 0788DD
This is mine:
Component: RLHS 220816 0 42 0106
Coding: 0714DD
I'd recommend to fix the other errors as far as you can (i.e. the error in the 61 module, and 03).
Have a play with the adaptation channels of your climatronic to fix that error:
climatronic error 00457 - Control Module for Network (J519) is solved by setting adaptation channel 1 of the HVAC to value 1
IIRC you have an official VCDS, no? Send your log to Ross Tech so they can fix the ASAM error for the PDC and then you'll be able to see what's happening there.
The 1K8 module is from a scirocco (I know why you fitted it, it's this MQB/PQ hybrid module) but was never fitted on PQ25. So I think that's why ross tech can't identify it.
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
iichel wrote: Thu Aug 13, 2020 9:05 am Regarding humidity sensor, I'm not sure your sensor has humidity sensing.
This is mine:
Coding: 0714DD
Thank - I'll change the value in 08 (HVAC) and order a new RLHS sensor. Then 2 of my problem will disappear ;)
Yes - you are right regarding VCDS. I'll send the log as soon I've got the other problems fixed.
