Hi
The car started to run very rough like it was running on 2 cylinders and began sending out code P0019E. I found that all 3 glow plugs were open circuit so replaced them. Still the same condition running rough but starting was getting a bigger problem. I swapped the cam sensor and the crank sensor to try and get rid of the P0019E but it remained and everything stayed the same. I can actually remove the cam sensor connector whilst it is running and it keeps running rough as before. I understand that the Crank sensor drives the tacho which indicates about 800 rpm when the engine is running and the engine speeds up fine when i press the accelerator.
This is a strange one. When the engine is running the code will be present if i clear the code with the engine running the engine will appear to fire on all three cylinders for maybe a second then reverts back to running rough so the P0019 seems to indicate the fault that is causing the rough running.
I have the engine light on and the glow plug light flashing. Also changed Brake light switch which was faulty. Engine still running on 2 cylinders plus code 19 still up.
Hope this makes sense to someone!
Any help would be great. Thanks
polo1.4 Twist 2004 running rough code P0019E
Return to “MK6 (9N) Polo - Years 2002-2005”
Jump to
- Polo Forums
- ↳ ID. Polo (1st Generation)
- Classifieds
- ↳ Parts For Sale
- ↳ Wheels & Tyres
- ↳ Brakes & Suspension
- ↳ Cars Breaking
- ↳ Unsorted For Sale Posts
- ↳ Cars For Sale
- ↳ Wanted
- ↳ Group Buy
- Performance & Technical
- ↳ DIY Guides
- ↳ ICE
- ↳ Chassis
- ↳ Powertrain
- ↳ Detailing / Bodywork
- ↳ Electrical
- Non-Polo Vehicles
- ↳ Seat Ibiza
- ↳ Skoda Fabia
- Polo Community
- ↳ Announcements
- ↳ Club House
- ↳ YouTube Videos
- ↳ Photography and Photoshop
- ↳ Reviews and Features
- ↳ Meetings & Events
- ↳ Meetings & Events Gallery
- ↳ Members Rides
- ↳ Was that you?
- ↳ Virtual Post Cards
- ↳ Forum Technical Help!
