OBD2 communication problem
Hayden1470
Drives: Volkswagen Polo 2000 6N2 1.6 GTI
Post by Hayden1470 »
Hey guys,
In my GTi I currently have an engine management light on, an airbag light and my Aircon seems to turn itself on and off whenever it wants. I can't scan anything other than abs on the car to find faults as all I get is "link error". When I try to scan I can hear what sounds like the headlight levelers adjusting. I have checked fuses and all seem ok. And have tried unplugging and cleaning up the Aircon control unit and the clocks. Is there anything simple I should check first before going through wiring?
Mot is Thursday and want to get it sorted before then.
937carrera
Drives: 2000 Polo GTi
Re: OBD2 communication problem
Post by 937carrera »
What are you using as a scan tool ?
Very unusual to be able to read ABS codes and not the standard OBD codes......
acabral88
Drives: Polo 6N2 GTi
Post by acabral88 »
Hi, I have same problem when I try to scan with VCDS or Autel.
I have this problem since the central locking stopped working.
The central locking pump is working perfectly in another car.
The windows work fine but without the automatic function (comfort?)
I've already tested the solutions I found here but without success.
Any solution please? :cry:
All fuses OK.
luebberspursifully
Drives: car
Post by luebberspursifully »
good post
