Fabia BCM 090B problem.
Forum to discuss the Skoda Fabia
денисЕрмолицкий
Drives: Skoda fabia fl
Post by денисЕрмолицкий »
Hello everyone from fighting Belarus). I replaced in my skoda fabia bcm 087h with 7e0937090b. I also installed a light and rain sensor. I did everything according to the scheme from the forum. https://www.drive2.ru/l/458624168083122501/
After installing and connecting the light according to the 2016 scheme, the high beam and fog lights do not work. The front and rear fog lights do not work, although the cornering light in the fog lights works fine. I checked the wires 4 or 5 times, everything according to the diagrams. Maybe someone can help me ? VCDS reports that there are no errors. encoding I am attachingImage
Thank you all for your attention.
денисЕрмолицкий
Re: Fabia BCM 090B problem.
Can you perhaps post an autoscan from before and after?
денисЕрмолицкий
iichel wrote: Fri Sep 25, 2020 10:20 pm Can you perhaps post an autoscan from before and after?
Unfortunately I didn't have any autoscan left before the upgrade
