"Automatic Hazard Lights Activation during Emergency Braking" - Enable this function using VCDS
Posted: Sun Oct 11, 2020 2:50 pm
by ho8882000
Enable the "Automatic Hazard Lights Activation during Emergency Braking" function using VCDS, the method is shown below:
- Polo.JPG (246.01 KiB) Viewed 3357 times
Re: "Automatic Hazard Lights Activation during Emergency Braking" - Enable this function using VCDS
Posted: Wed Oct 14, 2020 8:36 pm
by mjsaville
Thanks for this, I will give it a go when I get some spare time. Can't believe no one else has responded or thanked you for putting this post.
MJ
Posted: Wed Oct 14, 2020 10:41 pm
by Stuart_Rendall
I'm almost 100% sure here in the UK this is a standard feature and has to be coded to a new vehicle as standard so UK Polos should have this anyway.
Posted: Wed Oct 14, 2020 10:52 pm
by SRGTD
Stuart_Rendall wrote: Wed Oct 14, 2020 10:41 pm
You’re correct Stuart, it does seem to be a standard feature on UK Polos; page 62 of the owner’s manual or if accessing the online version of the manual on
www.Volkswagen.co.uk it’s under Safety -> In an emergency -> Making you and your vehicle safe;
Depending on the vehicle equipment, the brake lights flash rapidly if you brake sharply or initiate full braking at a speed of more than 80 km/h (50 mph). This provides an especially conspicuous warning for the following traffic.
If you then continue to brake, the hazard warning lights will be switched on automatically at speeds under approximately 10 km/h (6 mph). Once the vehicle starts to accelerate, the hazard warning lights will switch off again.
Posted: Thu Oct 15, 2020 8:51 am
by ho8882000
mjsaville wrote: Wed Oct 14, 2020 8:36 pm
MJ
Thank you for appreciating my effort
I spend time to work out these stuffs, and I am sharing these information free of charge.
But after 184 views, you are the 1st person to say thank you.
In the future I think it is better to just keep the information for myself.
- UK.JPG (24.74 KiB) Viewed 3171 times
Since you also work on VCDS, so maybe you will also be interested in the following post, FYI:
https://www.uk-polos.net/viewtopic.php? ... 23#p575623
Posted: Thu Oct 15, 2020 8:54 am
by ho8882000
SRGTD wrote: Wed Oct 14, 2020 10:52 pm
"Depending on the vehicle equipment"
Posted: Thu Oct 15, 2020 9:05 am
by SRGTD
@h8882000; I don’t think it’s lack of appreciation by other forum members. I think the majority of members on this forum board are UK based, so although your hazard lights activation is of interest, depending on the vehicle equipment it’s something many of those forum members may not need, hence the lack of responses on this occasion.
Please continue to share your knowledge - it’s this knowledge sharing by the forum members that makes the forum a really valuable resource for Polo owners.
Posted: Thu Oct 15, 2020 11:03 am
by OomStu_ZA
I'm sure my GTI here in ZAR has this feature already to be honest.
