Retrofit PLA Park Assist
Hi there, does anyone do this?
Im stuck in the part of coding the ABS Module cause my VCDS doesnt show a description of each bit and the XAGICO manual is not the same in terms of coding.
Any help please?
Any help please?
fletch555
- Drives: Polo GTI+
Re: Retrofit PLA Park Assist
If you get this working, could you provide a how to guide please?
I need the right coding in ABS module. Anyone can help?
Hello?
Scotty_boy vw
Is it me you're looking for!!!!
Hello Scooty, im really stuck with this.
I got the PLA 3.0 5QA module so i changed all the coding related with these. I didnt change the ABS coding cause VCDS has no support information so im stuck.
When i put the reverse in my car it says PLA Cancelled.
What is wrong with these?
Scotty i see that you have a very similar ABS module. You are golfman in Ross Tech forum right?
He's Lionel Richie on some Karaoke forum.alanlaos wrote: Thu Apr 01, 2021 1:50 amScotty i see that you have a very similar ABS module. You are golfman in Ross Tech forum right?
hhahahahhah thats leaves me calmmonkeyhanger wrote: Thu Apr 01, 2021 2:35 pmHe's Lionel Richie on some Karaoke forum.alanlaos wrote: Thu Apr 01, 2021 1:50 amScotty i see that you have a very similar ABS module. You are golfman in Ross Tech forum right?
After 6 months of searching information about this retrofit in a Polo brazilian production finally was made.
Thanks to Scooty boy and Lazo Eric who help me with this.
ziobigiu84
- Drives: polo aw1
how did you do?
ziobigiu84
- Drives: polo aw1
i am doing the same job but i can't.alanlaos wrote: Sun Apr 18, 2021 12:04 am After 6 months of searching information about this retrofit in a Polo brazilian production finally was made.
could you help me?
Dear All.
I try to do this too and I already have all installed but I can not how to code the ABS 2Q. Could you help me with this part.
Greetings
Greetings
- OomStu_ZA
- Drives: 2019 VW Polo GTi
lol
