Dipped light problem
Posted: Sun Nov 29, 2020 10:25 am
by DelR
Hi everyone I’ve just signed up to the site. I have a 2013 polo 1.4 and have recently had a problem with the dipped beam on the headlights. Changed bulbs over and checked fuses ok but dipped still not working. All other lights are working full beam etc. Is there a relay for the dipped beam that I can check or am I looking at the stalk switch?
TIA
Derek
Re: Dipped light problem
Posted: Sun Nov 29, 2020 11:50 am
by iichel
what headlights do you have? h4 or h7?
Posted: Sun Nov 29, 2020 1:20 pm
by DelR
It has H7
Posted: Sun Nov 29, 2020 1:40 pm
by iichel
if the fuses are fine (39 and 59 IIRC) it could be an issue with your light switch or low beam relay.
the low beam relay is number 7 on the picture
- Rosa Line Relays 1.png (365.32 KiB) Viewed 1212 times
Posted: Sun Nov 29, 2020 2:25 pm
by DelR
Thanks for the help I’ll have a look at the relay first. So when you say switch are you referring to the main light switch or the stalk switch that switches between dipped and main beam?
Derek
Posted: Sun Nov 29, 2020 2:54 pm
by iichel
if I understood you correctly, it's the low (dipped) beam that is not working. the low (main) beam is working.
the low beam goes:
power supply to relay (i pointed out to you) to fuses (39 and 59) to headlights
the relay is operated by your light switch, pin 7.
you could rule out the light switch or relay by putting 12V on pin 7 of the light switch directly
(remove light switch, ignition on, connect a wire from the red wire of the light switch to the white wire)
Posted: Sun Nov 29, 2020 5:02 pm
by DelR
Yes that’s correct the low dipped is not working but the main beam is working ok along with sidelights and fog lights.
Thanks I’ll give that a try and report back
Derek
Posted: Tue Dec 01, 2020 9:11 pm
by DelR
Update- I removed the lighswitch from the dash and put a short in between pin 7 and the pin opposite (red wire). Dipped lights still not working but could hear and feel the relay energising and deenergising. It appeared to be roughly where you pointed the relay out (number 7) but isn’t the type that’s labelled in that diagram, it’s a 646. Anyways I swapped this one out for another 646 and same thing happened. I’ve attached a photo to show what my relays look like. Does this mean the light switch and relay are ok and the fault lies somewhere else?
- 4CA42BAC-4F77-475D-8BA1-7704C904598F.jpeg (2.07 MiB) Viewed 1146 times
Posted: Tue Dec 01, 2020 10:27 pm
by iichel
do you also hear the clicking of the relay when rotating the light switch to the appropriate position?
do you have a multimeter? if so, please measure the voltage on fuses 39 and 59 when the dipped beam is on.
Posted: Thu Dec 03, 2020 11:46 am
by ciclo
DelR wrote: Tue Dec 01, 2020 9:11 pm
Update-
Yes, for your 6R model (2013) there are other diagrams for the arrangement of the relays, however, the relay you swapped is the correct one.
Hmm... double check that the connectors for the H7 bulbs you replaced are seated correctly. To discard simple things.
iichel wrote: Tue Dec 01, 2020 10:27 pm
+1
Logic indicates that fuses 39 and 59 could have blown.
