Ok total Noob here.
I am upgrading factory Stereo in Polo 63 plate.
I am looking at this particular set up : https://incartec.co.uk/product/Volkswag ... 14-IGN-230
Now will this simply replace what I have fitted, once the quad lock iso harness is attached ?
Is this model polo a 'can bus ignition' ?
As I said, I drive them and sing in them, I don't fix them.
Any help welcome, thanks.
Canbus ignition ?
Re: Canbus ignition ?
It looks like they'll be including:
Quadlock to ISO radio adapter harness, with CANbus ignition and antenna adapter (20-156A-IGN)
So I think it will be more or less a plug and play operation
What is canbus ?
Do I need to do anything else apart from 'plug and play' ?
Canbus is the name for your data network in your car.
I think you should be OK with the set you're showing but I'd recommend to ask the seller
I will
ty
ty
Hi again guys.
So I purchased and installed the Pioneer stereo and iso harness.
All worked well for 2 days but all of a sudden, I get intermittent power to the unit.
If I unplug the Canbus interface and reconnect it, it powers up.
Do you think this is a faulty Canbus adapter ?
Or a wiring issue ?
TY.
Or a wiring issue ?
TY.
