Gear box output flange
Nashy272
Drives: 2006 9n3
Post by Nashy272 »
I have recently had an issue where my driveshaft bolts sheared off. I have taken the output flange out of the car and the what I assume is a copper taper ring which is located above the spring has broken into bits. I was advised by a neighbour who is a mechanic that if I was to glue them together and put it back on all would be ok. However in doing so it has broken into bits again and I have lost one of the bits. I am now in search of either a replacement ring or an intact gearbox output flange complete with the ring.
Does anyone know where I can find one or a way of getting around it
CarbonChaos
Re: Gear box output flange
Post by CarbonChaos »
It may sound obvious but have you tried TPS for a price ?
