Intermittent rear wiper
Andrew S
Drives: Polo 2004
Post by Andrew S »
My rear wiper does not do a complete wipe, it goes so far, stops then suddenly start and keeps repeating this until it gets to it’s original position.
Is this a relay or cut out under load?
Any help appreciated
Andrew
CarbonChaos
Re: Intermittent rear wiper
Post by CarbonChaos »
Is the centre nut tight or the arm broken ?
Andrew S
Drives: Polo 2004
Post by Andrew S »
Hi
Good point, I will check as it’s a nee arm a month ago. It doesn’t go below the screen
Thanks I’ll check :)
Andrew S
Drives: Polo 2004
Post by Andrew S »
I have now checked and the wiper arm is not loose on the spindle :(
I understand there isn't a separate relay.
The front wipers are fine and so is the intermittent setting
The problem I have on the rear is that the arm moves almost halfway across teh rear screen, then pauses for say 20 seconds then completes the sweep and the same on the return.
I am presuming this will now be an MOT failure which is due 4th Jan, typical
Any help appreciated as I was thinking of buying another motor etc
Andrew
Andrew S
Drives: Polo 2004
Post by Andrew S »
OK, have been out to the car this morning with a view to lubricating the spindle, checking the wiper arm was not loose and also that a new arm is not causing a load on the motor by the drag.
I have pulled the arm away from the glass so there is no load and this is what it does
https://youtu.be/7OfqjKrRLC4
Is this the motor causing this?
A fuse hasn't blown and there must by power to the motor
Any thoughts greatly appreciated
Andrew
CarbonChaos
Rear wiper not part of an M.O.T
Andrew S
Drives: Polo 2004
Post by Andrew S »
Cheers, that’s a relief, thanks 👍
CarbonChaos
Does the wiper work ok if you wash the rear screen ? Ie does it do a full and continuous sweep while washing.
Andrew S
Drives: Polo 2004
Post by Andrew S »
Hi, yes, strangely is works fine full sweep. So as I stop washer it goes back to the same issue.
What does this mean ?
Andrew
CarbonChaos
I think possibly the timer relay has failed, so it’s too quick not allowing a full sweep of the screen.
Although I can’t find a proper relay diagram online I’m sure there is a relay controlling it, it may be a separate item or integrated into the BCM , this you could call your local dealer about worth a call to see.
May be others have a view on your issue
