Polo 6r ESC light and MFD speedometer.
jamesradley
Drives: 6R
Post by jamesradley »
Hello, today I installed a new set of wiper stalks to enable the MFD in my 2010 6r, since reconnecting the battery I have had an ESC light on which will not go away, when scanning using Carista it cannot connect to the ABS module.
I was also wondering what coding I need to do to be able to scroll to the digital speedometer on the MFD.
Thanks all in advance.
https://photos.app.goo.gl/ArJjaa1bS17E1Rqw8
Re: Polo 6r ESC light and MFD speedometer.
Did you twist the slip ring?
MFA is byte 1 bit 3 of the instruments IIRC
jamesradley
Drives: 6R
I have enabled the MFD and I can scroll through all the options but Speed display is not there.
As for the slip ring it's possible that it was at some point as it was loose in the packaging from ebay.
If you replaced the slip ring you need to calibrate the steering angle sender
jamesradley
Drives: 6R
How do I do that?
What kind of tool do you have?
jamesradley
Drives: 6R
I have an obd11 elm tool and carista
I don't know how to use these tools I'm sorry
jamesradley
Drives: 6R
Do you know the coding values, I have an obdeleven tool now so can do long coding
No you need to do a basic setting in the abs unit but you said you can't talk to it and I don't know how to do it with obd11
jamesradley
Drives: 6R
I can talk to the ABS unit now, what am I looking for and I'll see if I can find it.
jamesradley
Drives: 6R
This is the read out from G85 https://photos.app.goo.gl/DDpksaxScv2MVfmw9
jamesradley
Drives: 6R
Traction control light fixed. Still need help with digital speedometer,
Thanks for your help iichel
so what you need to do is
login / security acces 40468
turn the wheel from lock to lock to lock to lock
steering wheel straight
drive a a bit, very straight, very slow
basic settings
basic setting of steering wheel sensor
assuming your replacement slip ring has a sensor, of course
jamesradley
Drives: 6R
If anyone needs the instructions for digital speedometer just follow these I found on facebook.
Choose Australia as the region for the cluster and save that code. Then press the left button that’s on the cluster three times. The mileage will begin to flash. Press the right button then the left again. Done. Then it’s just a matter of scrolling through your different displays using the end of the wiper stalk and it should show up
https://photos.app.goo.gl/gvAcHuFtyLVAkYW77
