DAB coding
- J+silva
- Drives: polo conf.
DAB coding
Hi, I have retrofit my mib and it has dab radio but its not active. I have tried to enable dab antenna in byte12 and in 5f change band to EU Band III, it appears the indication of dab in the radio but it loses the sound it is only static. Can someone help me with this problem? Thanks.
Re: DAB coding
Did you fit a DAB antenna as well?
- J+silva
Re: DAB coding
I`m waiting for it. Does the lack of the dab antenna prevent the FM band from working?
- J+silva
Re: DAB coding
Hi,I didn't explain myself well after making these changes I only hear statics and I can't change to fm band must have missed some step to activate the dab. Can someone that has radio with dab tell me how is it encoded? Thanks
