Digital Radio - no dab signal
joshua
Drives: Mk 7 1.2S
Post by joshua »
Hi guys,
Thanks for the various posts on here guiding me to the bits I needed for a radio upgrade. Have installed a Pioneer DAB unit, connected via canbus so comes on with ignition etc.
From a previous post on here - have also installed Fakra to SMB DAB + Aerial Splitter. FM etc. works ok - but it won't pick up any digital stations. Have connected the aerial splitter / amplifier power lead to one of the spare blue (aux power) leads on the wiring harness - but still no joy.
Anyone managed to get a DAB until working with the existing aerial in place?
Also - the Pioneer has a DAB aerial power setting on / off (have tried with both - no luck either way).
Any suggestions?
Cheers,
Josh
Re: Digital Radio - no dab signal
Personally I would not expect much until you had connected it to a DAB aerial, I've had DAB reception with a cheap windscreen aerial placed on the back of the passenger's seat back and not connected up its built in power supply - I only bought and used that to make sure that the DAB radio was actually working before doing all the hard work installing a DAB aerial as per factory fit.
ValleyForge
Drives: 9N3 GTI
Post by ValleyForge »
I did the DAB upgrade and put a BlauPunkt sharkfin on the roof. Took maybe 10 minutes (and about 3 weeks to get the correct FAKRA cables).
And the GPS is much faster and more accurate.
