I need help for-test cluster on bench Polo 6R wiring
Posted: Tue Jan 05, 2021 10:45 pm
by mahesh_parmar
Hi all,
Can someone help with a bench cable connection diagram for testing & programming instrument clusters for the polo 6R. What part I need for test bench and wiring help me please
Thanks.
Re: I need help for-test cluster on bench Polo 6R wiring
Posted: Wed Jan 06, 2021 7:25 am
by amer6R
Posted: Wed Jan 06, 2021 7:02 pm
by mahesh_parmar
amer6R wrote: Wed Jan 06, 2021 7:25 am
I have this but can’t work need with gateway wiring
Posted: Wed Jan 06, 2021 7:34 pm
by gelotus
Would be better if you tell us exactly what do you want to do with the cluster, for immo programming you need only terminal 15, terminal 30, gnd, can low and can high pins, gateway is not needed, same with vcds for coding and adaptions.
Posted: Wed Jan 06, 2021 11:56 pm
by mahesh_parmar
gelotus wrote: Wed Jan 06, 2021 7:34 pm
I want for vcp and vcds
Posted: Thu Jan 07, 2021 1:12 pm
by gelotus
obd pin 16, cluster pin 31, 32 -> +12V
obd pin 5, cluster pin 16 -> gnd
obd pin 6 -> cluster pin 28
obd pin 14 -> cluster pin 29
