Pressure sensors
J+silva
Drives: polo conf.
Pressure sensors
Post by J+silva »
Hi I wish you could clarify a doubt. The vw polo has pressure sensors? I am looking to change the rims and the salesmen say that the polo does not have pressure sensors, but i have pressure settings in the radio.
Re: Pressure sensors
The ABS sensor measures rolling circumference, if it gets smaller (beyond a defined threshold), you get a low pressure warning. No actual sensors in the wheel itself.
J+silva
Drives: polo conf.
Post by J+silva »
monkeyhanger wrote: Fri Jan 22, 2021 6:55 pm The ABS sensor measures rolling circumference, if it gets smaller (beyond a defined threshold), you get a low pressure warning. No actual sensors in the wheel itself.
Thanks for your answer.
