1.4 tsi ACT clutch torque limit
Bongobob
Drives: Blue GT
Post by Bongobob »
Hi, does anyone know the maximum torque limit of the OEM clutch in the 1.4 Tsi act MT? I know the car puts out 250Nm, but is the clutch at its limit with this output?
Re: 1.4 tsi ACT clutch torque limit
no the gearbox can do about 350nm
Bongobob
Drives: Blue GT
Post by Bongobob »
Thanks, I thought the gearbox was the MQ350, but I’m wondering if the clutch is rated the same or if it’s the same clutch used in the 1.8 gti manual?
Dink
Drives: 2015 GTI
Post by Dink »
The 1.8 clutch isn't great as i believe it is fairly close to it's maximum torque with the stock tune (mine started slipping on stock power) I'm guessing it was designed to sacrifice it's self to protect the gearbox.
I've pushed over 500Nm through the box and it's just ok.
Bongobob
Drives: Blue GT
Post by Bongobob »
So if the 1.8 gti manual is 320Nm, and I planned to remap my 1.4 to 300-310Nm, it should be ok...?
Dink
Drives: 2015 GTI
Post by Dink »
If it does use the same clutch as the 1.8 I'd say you will be ok.
Bongobob
Drives: Blue GT
Post by Bongobob »
